Re: Clutch sticking on F-20
Posted by moseed on March 31, 2008 at 07:29:39 from (207.177.239.36):
In Reply to: Clutch sticking on F-20 posted by BIG BORE 20 on March 30, 2008 at 20:51:04:
BIG BORE 20 said: (quoted from post at 20:51:04 03/30/08) VA Gasman,
I have had mice get inside the bellhousing through the timing hole in the front. They built a nest and wet in there and made a mess. You can pull the little plate off the bottom of the back cover, There are two bolts to remove it and check things out. Some guys over greased the throw out bearing this would be a good time to clean extra grease out of there. I would not put something to hold the clutch down it will compress the springs in the pressure plate that might weaken them in my opinion. The serial number is in three places, Tag on tool box, motor block, and frame rail all three #'s match on my tractors.
I have heard both sides of the weak spring argument. Mechanical Engineer friend said that good springs will not be weakened if stored compressed or with tension. To many "old boys" have been doing it for too many years for it not to work. I don't think they'd want to make more work for themselves long term if it weakened the springs to block a clutch.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
