It sounds as though you may have the timing marks off. While you check that, another thing you should do is check that you have the right crankshaft installed. Doesn't appear that you have enough stroke. It has happened on 560's, where a 460 crank was installed. You could start them by pulling, but couldn't pull a setting hen off the nest. Two ways to check that. One-Thru spark plug opening, use a piece of 1/8 brazing rod and have some one turn the engine slowly while you keep pressure on the rod, and follow the piston to the bottom. Mark rod at opening of plug hole, then proceed to the top of the stroke and mark again. That will give you the approximate stroke. Bet that's part of the problem. The other way would be if you pulled the head, simply measure travel of piston thru the top of bore. Good luck Rifler. IntHar
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
