Most likely a broken tooth on a gear in the range transmission. In high range the speed transmission output shaft is coupled to the pinion shaft in the rear end so no power is transmitted through any of the range transmission gears. You would most likely be able to see the problem if you remove the cover on the left side of the rear frame just in front of the brakes. Any repair involving replacing any of those gears means a complete disassembly of the rear frame. The differential has to be removed before you can take out the pinion shaft.
Flat rate for range transmission overhaul is 15.7 hours without a cab. Most likely there will be some final drive bearings that need replacing so any of that type of work is in addition to the 15.7 hours.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
