Posted by jd b puller on April 18, 2008 at 15:45:26 from (24.225.90.65):
In Reply to: E85 and Farmall H posted by 160dan on April 18, 2008 at 14:48:52:
You'll likely need to rejet your carb, as the fuel/air ratio is about 8:1 vs. 13:1 for gasoline. All the other comments about Ethanol eating rubber should be heeded as well. If it sits in the tank long, it will draw moisture from the air and create this slimy stuff in the tank... You'll also use more of it than straight gas. If you can buy it for 2 bucks a gallon, it will far offset that, but if you're not careful it will either run really lean or not at all..
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
