mkirsch: Not completely so, if you just break into the high pressure line, use a power beyond remote valve, with the return heading back to the high pressure line to the touch control, it will work.
You can also achive the same without cutting the line, if you tap into the correct ports where the lines enter the touch control. I seen many a C and SC equipped with loaders and plumbing done that way. They could use either their remote or the touch control rockshafts with the touch of the proper lever.
Personally I tapped into the high pressure line of a Farmall 300 with a power beyond remote valve, ran the return from power beyond valve on to the hydra touch and I had 5 remote valves, 2 on the power beyond valve and the 3 factory on tractor, all available at the touch of a finger.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
