Posted by Owen Aaland on April 28, 2008 at 02:05:34 from (65.165.246.73):
In Reply to: M FARMALL posted by DANETOWN FARMER on April 27, 2008 at 15:09:36:
DANETOWN FARMER said: (quoted from post at 15:09:36 04/27/08) Have a M FARMALL that wants to jump out of 5th gear. What is the fix for this problem?
Usually this is caused by a bad pilot bearing on the front of the mainshaft. It rides inside the input shaft and when the bearing gets worn it no longer holds the mainshaft and input shaft in alignment allowing the fifth gear spline to walk apart under a little load. If the bearing is good the splines can be quite poor on both the input shaft and fifth gear and still not cause a problem.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
