Janicholson said: (quoted from post at 19:12:41 05/03/08) It will work fine on 6v pos ground. if pulled to start the mag will rotate well enough to make fire. Pull it in 3rd gear at about 2 to 3mph, no faster.
Be sure to run a piece of wire up into the hole to the tank to assure fuel flow there.
The wheel might be loose on the rim, and that will make the noise.
The solenoid (relay)is not needed. a starter switch on the starter, with a pull rod, or a heavy amp starter switch at/next to, the dash is good also. John T troubleshooting guide, and other infor in the "search for" box will do wonders. this link is for the diagrams of choice. Stay with 6v on this one, withsingle "o" gauge wires to the starter and ground. JimN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
