Re: Farmall A need some advice....
Posted by Janicholson on May 03, 2008 at 19:06:32 from (208.54.95.115):
In Reply to: Re: Farmall A need some advice.... posted by francoisc27 on May 03, 2008 at 18:44:41:
One easy way is to pull start it. If it has spark, it should run! It is possible to use an ohm meter on coil windings, but even then, proof is in the spark. not the readings. Look up magnetos in Google. there will be diagrams detailed enough to use an ohm meter. Make sure it has oil in the crankcase, and watch the gauge to be sure it gets pressure up. I would pull it W/O the Mag operating (shut off) until oil pressure was shown on the gauge. There is no reason to ruin a good engine If it needs to be primed. To prime, use as pump oil can and pump oil into the oilpressure gauge fitting hole. as it begins to be filling the passages, it will get harder to pump. Sometimes a small rubber tube is needed to get a seal at the oil gallery to oil can spout. JimN
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
