Posted by RODGEinIL on May 25, 2008 at 11:11:38 from (64.136.26.231):
In Reply to: 5288 hydraulics posted by tj in iowa on May 25, 2008 at 09:43:13:
I can't answer the hydraulic question but I just had the same problem with the sentry on my 5488. There is two pressure switches under the floor pan in the cab. Kinda a pain to get at.. got to remove the mat, etc. You can switch the pressure switches from one to another to see if the problem is the odd numbered gears or even numbered. Easy to see if one is bad will be seeping/leaking oil.Also the sentry module has two relays on the bottom, switch these to see where the problem gears will be. Just swap them side to side. If any of this doesn't work the module could be bad. The module is in the fusebox at the bottom center of the dash, between the clutch and brake pedals. Sorry for the long post hope it helps!
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
