Posted by PungoFarmall on June 03, 2008 at 18:00:39 from (207.69.137.15):
Started my SA after an 8 month rebuild. Runs great but no charge on the ammeter meter. Needle moves to 2/3 amp discharge with ignition switch on. I search the archives and found the 5-step generator/regultor trouble shooting procedure. I was able to get the generator to charge by completing step 6; grounding the field post and jumping a wire from the VR BAT terminal to the GEN terminal. The gen started charging with 5 amps at full engine RPM. The charge rate fluxuated with engine RPM as it is suppose to. Drove around for a while with a good charging generator. But (there's always a but) after I shut the tractor off and restarted, the ammeter only showed a discharge again.
From what I read on previous posts, I think the VRs cutout relay is not closing for some reason and I may have to adjust the spring tension. Any advise?
6v positive ground system. Rebuilt gen. New regulator. Good grounds.
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
