Posted by Janicholson on June 03, 2008 at 18:38:55 from (64.83.197.176):
In Reply to: SA Regulator posted by PungoFarmall on June 03, 2008 at 18:00:39:
With it running at 3/4 throttle, ground the field post on gen to a clean ground. If it begins charging, you may be needing to get a new new regulator. If no difference, but it begins charging when the Bat to gen is jumped, again a new regulator, or reduce the spring tension just a bit on the cutout. Disconnect the battery cable before removing the cover to avoid sparks. If it is new, it may be under warranty. JimN
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
