M ignition and carburetor problems
Posted by Dr. Bert on June 07, 2008 at 14:15:57 from (72.36.57.176):
Installed a new 6 volt positive grd. VR this morning. When I start the tractor it will charge at a rate of 6 amps at moderate RPMs and almost 10 amps at high RPMs. However, when I shut the engine off (magneto ignition) the points on the cut-out portion of the VR will not open. Tried a different VR--same thing. Rechecked all the wiring, reread the VR installation instructions. Wire from the Batt. terminal on the VR runs to the hot side of the starter. What have I done wrong?
Secondly, I have removed and boiled out the carburetor twice, checked the float level twice, replaced the needle and seat,but the engine still isn"t running right. Adjusted the power valve as per instructions, then the idle adjustment. Engine runs decently, but not smoothly. Smooths right out if I pull the choke out about half way. Obviously starved for gas, but I can"t figure out why. Removed the screen from the carb. gas inlet. Sediment bowl and fuel line cleaned. What else would you suggest? Thank you.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
