Bert: As far as your ignition problem - I don't know. But, as far as the carburetor - if that carb is totally clean (every tiny passage) and the float level is "dead on" and working, then you have an air leak somewhere. HALF CHOKE = LEAN. It is either where the carb bolts to the manifold, or where the manifold bolts to the head. Crank the M and take it up to mid throttle. While it is running 'rough', spray some WD-40 around the manifold-to-head runners at the head. If it smooths out, you've got an air leak there and you will need to remove the intake and have it planed off smooth at an automotive machine shop, then re-attach it with a new manifold gasket. Or, you may have a cracked manifold. If so, replace. Torque to 70 lbs.
Do you have a gasket between the carb flange and the bottom of the manifold? A good gasket? That is where I would check next for an air leak.
After that, check valve lash. It should be .017" @ hot.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
