The timing is adjusted by rotating the cast frame where the bar attaches. The frame is threaded onto that big pipe. Look at it, and you can see threads showing. You will have to unhook the break a way bar, and lifting mechanisms in order to do it. I would suggest that it was out of time to start with if it kept on breaking pitman rods. I have mowed thousands of acres with a C-21, and 24 with standard pitmans, and no problems. Mowed lots of Bluegrass, and it don't get much finer or tougher to cut. To cure the bolt loosening problem doubl nut or brad the threads of the bolts. If you want you can email me, and I will send pics of the things I am talking about.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
