Posted by mkirsch on July 08, 2008 at 04:48:51 from (64.80.108.52):
In Reply to: hot coil on H posted by Andy in IN on July 08, 2008 at 04:11:47:
New points, condensor, distributor cap, spark plugs, and wires should be standard operating procedure for a "restoration" or "rebuild." If you're not replacing those basic, critical parts, what exactly are you "rebuilding?"
Please, don't waste your time dragging the tractor all over heck's half acres trying to get it to start. If a gasoline-powered tractor doesn't pop right off and run within 10 feet, there is something wrong that needs to be fixed. Towing it for "5 minutes" won't change that. Freud defined insanity as performing the same action over and over, expecting different results...
Why aren't you using the starter? The same reason the starter doesn't work (bad/weak/dead battery) may be why you don't have any spark. If the battery isn't producing enough voltage, the coil won't build up enough charge to pop off a spark.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
