Posted by BOBWA on July 08, 2008 at 06:35:30 from (216.46.133.14):
My Farmall "A" quit running.Through the process of elimination,I discovered there was no spark to the plugs from the magneto. Never had any trouble with the mag before and didn't know much about it.I did figure,though,it must have a coil and a set of points. Took it off and apart.Had the weird shaped,old coil tested.It was no good.The points were clean and working fine. They wanted $200.00 for new coil.DAAAAA!!! There MUST be a cheaper way.I'm always willing to try something once. My other tractor has a $20.00 coil hooked up to a distributor and points. Why can't I do the same. I threw away the old coil,attached an ordinary 12 volt coil to the nearby oil filter casing and wired it to the points in the mag.I also discovered to change the condensor to a $4.00 common 12 volt one.,,,runs better than it ever did! My question to you guys is this,,,,,,, Did I invent this proceedure or is it in the books as a common,less expensive way to replace a faulty coil in a magneto??? What do you think? BOB
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
