Posted by JimB2 on August 07, 2008 at 19:15:52 from (99.241.179.24):
In Reply to: 495 case -ih brakes posted by coonhound on August 07, 2008 at 16:59:50:
Hi Hound, the following is from archives: Bleed the brake system, stop the tractor for 1 or 2 days and check one pedal at the time to see which is the side that has the problem. Unlock the pedal to make the test, because if you press both pedal at once there is an equaliser valve in the system. The pedal that goes down has a leak in the line or the brake piston. Bernard le mécano Québec Canada
Some other basic checks, make sure that only Hytran or equivalent hydraulic oil is in the transmission and the hydraulic filter is clean and the level is full or over full. Following happen to my brother on 454, he purchased a wood splitter at a farm sale. Connected it to his 454 and used it for a few days splitting wood. Afterwards he kept getting air in the brakes, turns out the hydraulic cylinder on the splitter was full of regular detergent motor oil and it was foaming in the transmission causing air bubbles in the hydraulic lines to brakes. Required complete drain of system and new filter.
Check brake hydraulic lines from brake cylinders across top of transmission.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
