Tim Powell here again; Farmall A timing problem
Posted by Tim Powell on August 15, 2008 at 17:51:37 from (72.228.48.232):
Ok; I took your advice and thanks. I spent a couple hours jury rigging a caliper that would measure the clutch housing ring gear diameter. Then I measured the degrees off before TDC the mag tripped and laid that out along the circumference and got 14 degrees. The 8 was bad guess. I've been through the timing sequence 30 times by now and not sure of anything anymore. I would have already started tearing the front end off but I had to go to a local Ag fair this PM.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
