Bummer. I hope the cam timing is correct. Assuming it is, you will have to remove the governor to fix it but the rest won't be bad.
Turn the engine to #1 TDC. The mag will have just tripped.
Take the distributor cap off and note the postion of the rotor then remove the mag.
Pull the governor housing off. You will run into interference from the fan shroud so will need to remove it or loosen and tilt the radiator or whatever it takes to get clearance.
Pull, rotate and reinstall the governor assembly. You can look for the marks. They should be visible at this position. If not, turn it 2 teeth and reinstall. You need to turn it to the left. There are 33 teeth, so each tooth is 11 degrees.
Reverse the steps to reassemble. Except I would install the mag and try to time it as soon as the governor housing is in place. That minimizes the rework if you find it needs one more tooth. Finish reassembling after it is timed. When installing the governor, make sure the rotor is pointing the same way it was when you removed it. If needed, rotate the magneto backwards until the rotor is in the right place.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
