The exterior timing lines on the pump housing and adapter are there only to get you close. The actual timing should be set using the internal timing marks and the marks on the front crank pulley.
Turn the engine crankshaft clockwise when looking at it from the front. Stop when the pointer on the front cover is in line with the correct degree of timing advance. With the fuel shut off at the tank, remove the timing cover on the side of the pump. The scribe marks should be aligned. If you only see one scribe line, rotate the crankshaft one complete revolution. If the marks are not aligned, rotate the pump housing until they are. If you had to move the pump, rotate the crankshaft two revolutions and recheck the timing. Readjust and rotate until the are aligned after turning the crankshaft.
Once you have the timing set you can use a chisel to remark the pump housing and adapter so you will not have to do the internal check again if you have to R&R the pump again.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
