Farmall JD has a point I would like to know why it is high. The 666/686 used the D312 - smaller sister to the D-414/436/466 that could develope pinholes in the cylinder sleves. Don't think the D-282 had the problem as bad as the D-312.
The solution to the sleve problem was to add DCA4 to the coolant and a water filter on the D-414/436/466.
If the oil is milky at all take the tractor back as new sleves (engine overhaul) will cost you a few thousand in parts alone. Also, the sleve pinholes we're at the bottom of the sleves and don't effect engine performance. Yes the water will quickly kill the engine.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
