Ah the PTO clutch lock up pressure should be set to no less then 235 as they can walk thru the lower setting under heavy loads and myself i like 235 - 245 . You need a gauge that will read 600 lbs as i have found over the years that a gauge that has a bit higher capacity does a better job. and if ya make a mistake and go over it will tell ya better then just pegged the gauge. Next ya need the special fitting to screw into the test port . You loosen the lock nut on the valve stem and screw the valve stem into the nut to raise the pressure . But you also need to check the low engauge pressure as this is set with shimm's on the valve stem down inside the valve. Now if ya can not get your local Case I H dealer to sell ya special fitting the buy a new plug and O/ring and take one or the other and drill a hole dead center and well a fitting on the one plug and add piece of hyd. hose from the fitting to the gauge. Pressure is set at full rated PTO speed with the hyd. oil temp at between 150- 180- degrees. IF ya try setting it when cold then you will be way off when operating temp is reached.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
