Re: hydraulics on an 856 international
Posted by the tractor vet on October 05, 2008 at 18:23:02 from (99.167.208.219):
In Reply to: hydraulics on an 856 international posted by howard mills on October 05, 2008 at 18:01:09:
the main hitch pump is located in the lower left of the rearend just ahead of the left rear axle . My be something as simple as a sheared key on the pump drive gear .A new key a new lock nut one gskt . and a O/RING will fix that. You must drain the hyd, oil and to do this you will need the bottom third of a 55 gallon drum and it will darn near fill it . Now if this is not the problem you did not say if you have steering and breaks and if the tracor will or will not move if it has a T/A . Now if this is the case then the repair gets a little more involved as the tractor will have to be split at the bellhouseing and you will need a new pressure plate a PTO input shaft bearing seals and gskt and since you are replacing the pressure plate ya might as well reface the flywheel and put in a new clutch disc.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
