Posted by caterpillar guy on November 04, 2008 at 03:00:50 from (64.12.116.73):
In Reply to: international 574 D posted by Brian Henderson on November 03, 2008 at 18:46:42:
As for the number you found can't say. It should end with ( R2 )or somthing like that. There should also be if the crank has been turned another number like 0.020 or such that will be the amount of undersize also will be on the rods. Bolted to the bottom of the block is a set of balancers that time with the engine. When we put the sleeves in ours 20 years ago we didn't put them back in and no difference in the running that we could see. that engine has wet sleeves also. Meaning that coolant is against them. They should push out easy just something on the bottom of the sleeve and a jack up from the bottom and out they come. This is of course if it is still in the tractor.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
