Posted by hayfarmer on November 05, 2008 at 18:09:00 from (74.209.9.107):
In Reply to: M wont crank posted by NathanV on November 05, 2008 at 16:56:28:
Does starter make any sound at all? Could be that starter is stuck in ring gear, to check losen bolts holding starter on and move it a bit . Check connections on battery and on starter and ground. If it is 6 volt need excellent clean connections. Just because they look good does not mean there isn't a film especially on battery end. Make sure cables are in good shape. You can also pull starter off and check it for function off the tractor. Do you have the type with starter button top of the starter? There may be a bad connection between the contact on starter and contact in button. TRy the simplest things first and go from there.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
