There are several things that have to be tight to make rev. work the top cover has to be tight where the main shifter goes thru to the cam then the rev. shifter arm that works off the shifter cam must fit tight in to the cover and the roller must be in place on the shifter arm . Next the rev. shifter rod that runs down to the rev. shifter fork must be tight in the fork andusualy they get woren in the woodworf key slot . The way that set up works any slop will give ya fits So fist off get a I T manual and study the shifter set up then starting at the gear shift lever ya work your way down and fix repair replace any thing that has slop Go back into the archives and read up on this as i have gone over this many times . Next everything in the clutch adjustment MUST be set as i have outlined before. When everything is set the way it is suppose to be then she will shift with two fingers and there will be no need to slam it into gear.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
