Posted by LMack on December 25, 2008 at 10:43:00 from (66.156.32.45):
In Reply to: no spark at points posted by Richard Hayes on December 25, 2008 at 09:07:47:
I had a similar problem on a 200 that had been sitting for a while (years). When checking continunity through the distributor I found that I had voltage at the wire (new) on the outside of the distributor but no voltage on the stud. After I cleaned the stud I had fire. (The whole process took days and several post here seeking advice.) You might want to open the points and check for voltage at every stage, each end of the wire ring, the stud outside, the stud inside, then the point spring. Also check the ring for the condenser wire. Don't just assume that there is good contact from the wire to the stud or from the stud to the spring. Good luck! larry mcever
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
