Re: C vs. B engine
Posted by Ronnie Langford on February 12, 2009 at 06:32:04 from (67.61.105.10):
In Reply to: C vs. B engine posted by international embalmer on February 11, 2009 at 17:22:33:
gene bender said: (quoted from post at 10:32:43 02/12/09) Both are 113 cu in. The B does not have the place for the hy pump. They are interchangeable. But if you want the hy pump you need the C block. A few Bs left the Louisville plant with the block made for the C.They just put a plate over the hole. What is the purpose of your question. Are you needing to replace on or the other. They did speed up the engine for the C then went to the Super C with larger bore that can be done with the B block.
I am considering the purchase of a C and I am certain the engine will need extensive repair as it has been sitting with the exhaust open for years. My main concern was engine size.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
