Randy, my Dad has been plowing with a 20.8x38 in a 16" furrow for almost 30 years now, and I don't think he's given it a second thought. The amount of ground compacted is minimal in my observation, and the compaction is nowhere near what it was before plowing. You'll do a lot more compaction fitting the field up for planting.
Working with an "on land" setup as Dellbertt describes is certainly more comfortable, but not always possible. A plow is one of the heaviest loads you can put on a tractor, and when you're working the tractor to its limit, it becomes absolutely critical to have the plow hitched properly behind the tractor so that the tractor will pull the plow efficiently.
If you're not pulling the maximum plow behind the tractor, such as only 2 bottoms behind an M, you can do as Dellbertt describes because the tractor has plenty of power and weight to deal with the load being offset to one side like that. Put a 3 bottom plow offset like that, and the M will not drive straight, and you may not even be able to plow effectively.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
