Who rebuilds governors?
Posted by Shannon Snyder on February 17, 2009 at 17:39:34 from (128.46.109.185):
I have an 806 LP that has a tendency to get lazy when under light loads. Running at rated RPM it holds engine speed relatively well but still will slack off when the load lets up. I do custom haying with it and it is murder to rake with. I changed the governor with one off a 460, which helped the laziness to some degree but wouldn"t allow wide open throttle. I found another governor off another 806 with a 301 LP in it. This governor was better than the original but not nearly as good as I would like.
I also have a W-400 that doesn"t want to idle down. Once the throttle has been set past idle, you can forget low rpms for the rest of the day. Engine control is minimal to say the least. I checked to see that the control rod between the carb and the governor has the cog properly located.
I remember an ad in Red Power several years ago advertising an establishment that would rebuild governors. Now I can"t find the ad to save my self. Does anyone know of a place that would know what they were doing when rebuilding either or both of these governors?
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
