Posted by ChadS on February 18, 2009 at 11:25:48 from (4.224.78.54):
In Reply to: Who rebuilds governors? posted by Shannon Snyder on February 17, 2009 at 17:39:34:
Sounds like the governor weight pins are shot and the flywheights are sticking. I do rebuild governors to stock specs or pulling. New weights and pins will help for sure. the 806 governor is what you need to be using, the 460 is pretty much set for lower rpm usage, which can make a 301 underpowered real quick. The 400, may have the pins bad too,,, but the vertical linkage thats located under neath the little vent tube on the top of the governor,, this linkage is adjustable, and can wear out or break. If this linkage is out of adjustment, it will not idle and run erratic with high rpm,,,
the weight pins will stick too and it will pretty much lock up the governor and carb linkage to where ever the throttle postion will be,,,, and that can be wide open!!! Gather up all your governor parts, and take a look inside the governor on the 400,, remove the inspection plate off the side and have a good close look, if thigs are really sloppy and loose it needs repair, but it aint hard. Hope this helps, Chad 574-893-7437 TheTractorShop.com
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
