There are no "umbrella" seals on an 806 Roosa Master pump shaft. The pump adaptor housing has two lip type seals in it, one facing each way. The only other seal in an O-ring. The pump drive shaft as well as the driven plate inside the pump are marked with a dimple. As long as the pump is reassembled back on the shaft with the marks aligned the ump will be in time with the camshaft.
When I remove the pump on an 806 I remove the the insulator bracket from the injection lines so that I can separate them enough to slide the pump back between them. You will most likely need to replace the insulator pads so that the line do not touch the metal of the bracket. Vibration will wear a hole in them if they are not kept from metal to metal contact.
If the throttle arm is not wired back when the pump is removed it is not a big deal. Just make sure that the ends of the governor lever are back in the slots of the bushing and wire the arm back as you go to install the pump.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
