Re: Overdrive on a M
Posted by Janicholson on May 31, 2009 at 06:03:02 from (66.173.50.177):
In Reply to: Overdrive on a M posted by BSpauld on May 31, 2009 at 05:24:25:
The device he is talking about is called a 9 speed.
It was produced by several companies M&W, and Hiesler, to name 2. They are like an overdrive in some ways. and not in others. Many overdrives are after the transmission. These are in the trans affecting 1-2-3-4th gears only, leaving 5th (a direct to output shaft coupling)alone. When working it will not go faster than fifth would normally, it does give 4 gears in between the original 4th, and original 5th. Desirable yes. reparable probably. The most likely problem is a linkage issue. A stuck cable, or actuator.
Less probable but worse is broken internal components and or gears. JimN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
