Posted by John T on May 31, 2009 at 09:15:05 from (66.244.97.31):
In Reply to: 53 Super A not starting posted by Adrian Billheimer on May 31, 2009 at 08:58:16:
I'd be "looking at" a good battery charge the first thing, that may be allllllll she needs. If the points arent burned or carboned over they may be okay. Of course, leaving the ignition on may have overheated n harmed the coil, the other Id be "looking at" would be to see if the coils primary (between its lil + and - terminals) still has continuity (not burned open). An ohmmeter should show around 1.25 to under 2 ohms if its a 6 volt coil,,,,,,,,,of course, if it reads an open circuit its badddddddd..
Put a test pamp on the coils input (from ign switch) n turn her on and a test lamp or voltmeter should read hot voltage. Then place it over on the output (to distributor) terminal and there should be near zero volts when points are closed but hot battery voltage when points are open UNLESS the coils primary is burned open
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
