Posted by MN Scott on June 09, 2009 at 19:50:31 from (206.9.216.95):
Discovered were my rear hydraulic pump is sucking its air, 'I think'. I added oil with the flowrater hooked up and the engine idleing. When the oil covered the suction tube connection into the filter compartment the air stopped. It must be leaking enough air for the rear pump to get air but not the front pump as the inlet for the front pump is three inches lower. I then pumped oil below the tube and removed the filter cover. I plugged the tube and pumped the oil back in and a stream of oil is running out around the tube. So looks like I get to pull the lift housing to replace a little oring. Lot cheaper than a new pump tho.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
