Posted by scott mcintosh on June 29, 2009 at 20:45:24 from (216.180.197.23):
In Reply to: 806 mvc gear replace posted by josh braman on June 29, 2009 at 19:32:06:
You will have to split tractor at clutch housing,remove bolts from bearing holder,then remove bottom plate,also remove input shaft assy. then there might be enough room to slide gear of shaft then out bottom. If there not room then it will have to be split again to gain more room.This all from memory it's been awhile.Any more questions ask for the Tractor Vet.Scott
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
