Re: Water leak on 560 Diesel
Posted by Owen Aaland on July 11, 2009 at 14:08:35 from (65.165.246.156):
In Reply to: Water leak on 560 Diesel posted by Old School on July 09, 2009 at 19:24:58:
I have seen seen several pumps leak out the weep hole after they have been rebuilt. The cheap kits use an impeller that just has a machined surface for the seal to ride on. Any imperfections will allow coolant to leak out. The IH kits use a ceramic disk with a rubber seal pressed into the impeller. If the ceramic cracks the pump will leak. It is also possible that the bellows in the seal itself are damaged.
Verify that the leak is indeed coming from the weep hole. If it is you have a defective pump.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
