Posted by Theman on July 17, 2009 at 13:16:54 from (63.107.135.35):
In Reply to: H and the mesh gear posted by Thomas Keiber on July 17, 2009 at 11:41:33:
The tractor doesn't have to be split to remove either the top gear - or the one on the countersaft for that matter. Search the archives or follow your repair (service) manual for removing the pressure plate and drive shaft. The constant mesh gear is part of the transmission input shaft cage assembly which comes out of the front of the transmission case. While you are at it, carefully check the pilot bearing on the front of the sliding gear (top) shaft. Also, replace any worn or rough bearings in the housing and replace the seal if you even think it might leak in the next ten years. Gaskets for this were still available from Case/IH as of last year.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
