The way you describe the plumbing, you have a CORRECT two-way hydraulic setup. Your 3pt will power up and power down.
All you need to do is secure the Liftall lever back so that it is providing pressure. Hooking that nub on the lever should work, but maybe the linkages are worn. How much further do you have to pull it to make it work? Maybe weld a piece of key stock on the rod to take up the slack?
A bungee cord could be used to hold the Liftall lever back, or you might be able to secure a small hose clamp on the rod to hold it pulled back, but beware if you have to force it ahead for some reason, you won't be able to.
You will need to use collars on the cylinders to limit height. There is no position control available, unless you sit down and design it yourself. It drops down because you have a leaky christmas tree valve.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
