Posted by WayneMo on September 07, 2009 at 21:04:35 from (4.244.211.245):
I removed the gear set that positions the rotor bug and need to get it back in register. I see no markings on the two mating gears. Do I just position the gears so that the bug points to #1 cylinder wire as close as I can visually when the points are just opening? Then fine tune it at assembly by means of the slotted mounting holes on the body? Seems to me they should have put a marking on these gears! I have another mag that does not show continuity between the secondary outlet and ground which I guess means the secondary coil is open. Is that the normal mode of failure?
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
