Posted by ScottyHOMEy on September 18, 2009 at 07:21:49 from (64.222.247.18):
In Reply to: Super A Running Hot? posted by Pete 7 on September 18, 2009 at 05:50:52:
If you're running straight water, it will evaporate some, but I suspect the level that it's falling to is it's natural level, as there is just about a quart's difference between the top of the neck and where it will settle down to on its own.
You couldn't rule out a crack in the head or a bad head gasket that's letting some of your coolant get into the cylinder and burn off as steam, but you should be noticing the steam (as white smoke) if that's the case. If it's running right, I'd consider this the last thing to look at and only when everthing else has been eliminated.
I'd try draining and refilling with 50/50 antifreeze and water and see if it drops down to one level and stays there without overheating.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
