Posted by Gordon Mercer on September 22, 2009 at 17:44:27 from (24.230.119.203):
As a new member to this forum, I have a question I hope someone can answer. I was plowing snow last winter and my transmission started knocking. I split my tractor in two and found what the problem was. The bearing between the main transmission shaft and the transmission drive shaft was bad and the nose of the main shaft was damaged. I purchased a used main shaft today and and a drive shaft. The main shaft is mounted at the rear of the transmission with a triangular plate. there are several shims under this plate which set the gear backlash. Since I am replacing the main shaft with a different one from a different tractor. I need to set the backlash by adding or subtracting shims. I don,t know what the backlash specs are. If anyone knows this, please let me know. Thanks, Gordon Mercer, Spearfish, SD
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
