560 flywheel, 560 pressure plate with live pto hub removed. Then take a 560 clutch disk, have a M clutch spline installed instead of the 560"s.
M and 560 use the same backspacing from the rear engine plate to the back edge of the starter ring, I belive its 4 inches.
Im not sure on the starter ring,,, Id belive the 560 should work,, because,, I can put a 450 flywheel in a M and still use the 2 bolt M starter without changing the starter ring. So,, Id say you can use the stock 400 starter and the clutch setup from the 560 and bolt the two halves together. 560 frame rails bolt right up, and you can use a M-450 bolster if you decided to keep the 400 tin, with the overhead steering shaft. Hope this helps. ChadS
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
