Janicholson said: (quoted from post at 16:15:44 09/27/09) The best info I have is to assure all control valves are returning to neutral. The hydraulics are open centered in that position. The filter can cause restriction causing cavitation and pump damage. Cleaning often loosens grime and the filter needs to be changed once after the original. Some filter systems (NAPA) and others are different, and might flow more, check that option. There should be a latch on the PTO lever that locks it into gear. Check the linkage to determine if it is operational. Do not use it slipping, it is a very expensive error. Good luck, JimN
The hydraulic valves on the 460 are NOT open center. The system is a closed center system with an unloader valve to dump the oil back to reservoir when there is no demand from the valves.
The orifice/screen assembly in the control block allows oil to flow through and open the unloader valve. When any of the hydraulic valves are moved the oil flowing through the orifice is dumped and allows the unloader valve to close. That allow the system to go on high pressure.
The standby pressure on the system should be about 60 PSI. If the orifice becomes plugged or there is too much leakage through the valves the system will stay on high pressure.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
