Remove the large threaded cap on the front of the steering sector. Loosen the 2 set screws on the forward shaft locating collar at the steering wheel support. Uncouple the u-joint and rotate the steering shaft so it un-screws itself out of the steering sector. Note: there may be lube that will drain out. You may need to "assist" the u-joint as it slides off the end of the shaft. Remove the half-moon key, clean of the shaft & out it comes. I suggest replacement of the shaft seal at this time and use corn head grease for lube upon re-assembly.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
