Posted by jal-SD on November 04, 2009 at 06:48:24 from (71.38.30.28):
Have you checked the insulator on the distributor where the coil wire goes to the points? My H was giving me fits, would run good most of the time, sometimes would not fire at all. Chased the problem for quite a while & finally found a crack in the bakelite insulator on the distributor body, where the wire is bolted to the points (wire connected on outside of body, points on bolt on inside). Replaced the insulator with a plastic one from a Datsun distributor (I think that's what it was, you know about the CRS problem that us older guys suffer from on things that happened a couple of years ago) that the parts house found would fit and WHALLA - haven't had a problem since. Just a suggestion. (My $0.02 worth. jal-SD)
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
