Posted by Janicholson on November 09, 2009 at 06:36:40 from (199.17.6.27):
In Reply to: W-4 (H) engine racing posted by Panja on November 08, 2009 at 16:49:04:
If the linkage that connects to the hand lever is moving the governor through its full range, there are two possible factors. Loose intake manifold or carb can allow excess air into the engine, and if rich (or choked a bit) will race. Throttle plate is open more than it should be. If manifold and carb are not loose or leaking, the plate must be open more than idle. The plate can be loose on the shaft, the shaft can be sticking, the link shaft tab in the tube can be out of its slot, or the governor can be sticking. (main springs in governors open them, if broken or weak, they do not have high RPM. Good luck, JimN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
