If that Voltage Regulator is labeled L B F Id say underneath it has its ARM terminal SO YOU SURE ITS WIRED CORRECT??????
BAT on VR to Load side of ammeter FLD on VR to Gennys FLD post ARM/GEN on VR (underneath) to Gennys ARM post
LOAD feeds hot battery voltage up to the loads like lights and ignition etc usually via its being wired to those switches BAT input terminals
If the L terminal is not used loads can be fed off the load side of the ammeter (like on 3 terminal VR's) which is the same place that wires down to BAT on the VR
ONCE YOU GET IT WIRED CORRECT from the above or Bob M's Diagrams, then my Troubleshooting Procedure below will help diagnose the problem. The gennys output is on its ARM post but the open unloaded output of a genmy dont mean all that much. Its to what voltage it can raise a good batrery that matters. Id expect a 6 volt batetry to read 6.3 volts sitting there but if coupled to a good charging system at fast RPM the battery voltage should rise to 6.5 to 7 volts and a lil over.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
