Posted by VFMerc on November 13, 2009 at 14:50:19 from (98.110.125.83):
I have a 1953 H Model with a 6 volt system, magneto, 6 volt generator and 6 volt regulator (L/B/F) that I recently restored. When I run the tractor the ammeter shows no charging or possibly a very small charge. I've used the trouble shooting guide I found on line but can't seem to determine the problem. When the engine is off and lights are turned on the ammeter shows a discharge. When I start the engine and run at ½ speed or better, and place a voltmeter on the regulator F terminal I get 6.24 volts and the battery shows 6.1 volts. The ammeter shows no charge or perhaps just a little. If I turn the lights on, the ammeter shows significant discharge reading. Is it possible the generator / regulator is not putting out enough current to override the battery voltage?
I reversed the wires on the ammeter and confirmed the needle will swing to both sides of the "0". I pretty sure I've got everything wired right. I'm stumped.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
