rvirgil_KS said: (quoted from post at 01:30:11 11/14/09) The regulator connections would be
L (load) goes to hot side of light switch (and ignition switch if using distributor)
B (Battery)goes to ammeter
F (Field) goes to Field terminal on generator
There should be an Arm or Gen terminal under the regulator. It goes to armature on the generator. Is this one connected, you don't mention it so I wonder if that is the problem.
The F (field) terminal should vary in voltage. Be more concerned with the Armature voltage as that is the generator output.
With all properly connected, if you ground the field terminal it should show full charge.
Thank you. It is wire as you have indicated and yes the "A" terminal on the generator is connected to the "GEN" terminal on the under side of the regulator.
I did not know where / how to check the generator's output. I'll check the voltage at the "A" terminal of the generator with the engine running at 1/2 speed or better.
1. What should I expect to see on the ammeter with the engine running (lights off) if all is working properly?
2. Should I see a discharge indication with the engine running when I turn on the lights?
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
